database
I have database connection in my computer.when i create a data linking ,i want to link access in another computer ,how can i write the access pata in the other computer?
(3,128 Views)
If you want to access the file then it should work with that path. You have to share the C drive on the computer where the database is located.
Furthermore I would give that computer a name so can access this through a name. If the IP address is obtained through a DNS server then it can change.
(3,108 Views)
