data acquisition using CR3000 through labview
hi all,
I'm new to Labview and VI stuff. actually i want to acquire temperature and relative humidity data using HC2S3-L probe connected to CR3000 micrologger. i need to connect this to labview. CR3000 is working fine i checked it through PC200W.
I confirmed the rs232 connection through measurements and automation explorer it's present there and working OK.
I think the problem is in my labview coding. i selected the right COM and options are OK for VISA configuration but i don't know why I'm not getting the data. the output i get is ZERO.
can you guys help me here?
thanks
(2,893 Views)
Unfamiliar with that piece of hardware; however, most instruments require a VISA Write to request instrument data across the COM port.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(2,856 Views)
Hi, i recommend you checking on the LabVIEW examples. You check them on the help tab>find examples. There you can find the example named continuous serial write and read. You can configure that example with the info of you connection.
(2,838 Views)
Thank you DRMGRN, actually now i realized that the problem is with my cr3000 so for labview to read from the rs-232 serial connection i have to program the cr3000. still I'm not very sure but I'll try
(2,828 Views)
hi Minions , its cr3000 campbell scientific data logger and HC2S3-L is a temperature and and relative humidity probe mostly used in weather stations.
(2,827 Views)
