converting vi 8.0 to 7.0
Dear all,
I would like you to convert the following file(v8.0) to Labview 7.0.
Thank you in advance.
(3,301 Views)
The one version of LabVIEW that I don't have is 8.0 so I can't do a save as 7.0 for you but here's the block diagram (cleaned up some). It should only take a few minutes to recreate it.
Questions like this should be posted to the LabVIEW board.
Message Edited by Dennis Knutson on 10-14-2007 09:58 AM
(3,288 Views)
If you can post it in LV 7.1 I can translate it to 7.0 .
So I suppouse you have LV 8.0 , just open it with LV 8.0 and go to File -> Save for previous version And select 7.1 . Then post it here and I will translate it for you.
Jaime Cabrera
NI Applications Engineering Spain
(3,268 Views)
