03-13-2010 06:08 PM
Solved! Go to Solution.
03-13-2010 07:01 PM
Since it is an IVI driver, you would need to have LabWindows/CVI in order to modify it.
A switch is a generally a simple instrument. You can write your own driver or use the Instrument I/O Assistant. I would recomend using MAX or Hyperterminal to test communication before writing any code.
