connecting euro therm 6000 series recorder in labview
I want to connect  euro therm 6000 series recorder in labview ,using RJ45 i have connected the recorder to the system .Please guide further how to connect it to Labview
(1,145 Views)
HI
could you please share more information how would you like to connect to labview,is the device visible on NI Max?
(1,095 Views)
I tried to connect it using the existing Euro therm instrument Driver.
The recorder has a only option to get connect through RJ45, The IP address of the device is taken and tried using TCP/IP protocol ..but unable to communicate .
with NI Max i didn't try .. will check
(1,076 Views)
