code for a digital scales
hello
please can you help me with the scales.
i did a program to acquire data from the scales but the data was coded therefore i need a source code
thanks
Message 1 of 9
(5,787 Views)
Sorry, but your question does not make any sense. What scale? What program did you do? If you did the program like you said, you have the source code.
Message 2 of 9
(5,783 Views)
What is the make and model of your scales?  Do you have the user or programmer's manual?  Those usually tell you how to interpret what was sent to you.
Message 3 of 9
(5,780 Views)
hello
the program
thanks
Message 4 of 9
(5,775 Views)
Why are you asking for the identification each loop?  It looks like that is just confusing the scale.  Again, WHAT IS THE MAKE AND MODEL OF THE SCALE?
Message 5 of 9
(5,773 Views)
hello
the scales luttron Gm500
THANKS
Message 6 of 9
(5,771 Views)
You don't even have the vendor's name correct. You made the same mistake 6 months ago - https://www.ni.com/en-us/support/model.bnc-2090a.html
Your code makes absolutely no sense if the point is to read a value from the scale. You are just making things up with the idn query.
Message 7 of 9
(5,766 Views)
8 months later and he still can't get his equipment right.
His original post from June 2014. http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/library-for-digital-scale-GM-500/m-p/2886264
Message 8 of 9
(5,762 Views)
Did you get a programmer's manual with the scale?  You may have to contact Lutron in order to get one.  That should tell you how to get your data.  I'm not finding one online.
Message 9 of 9
(5,751 Views)
