clear RTS line with ComponentWorks serial control.
I'm using a Velleman 345DI DMM, the instrument requires RTS set unasserted. How can achieve this in ComponentWorks (Win 2000, VB 6.0, Mstudio 6.0)
(3,841 Views)
Hi there,
There is a VISA property you can use to set the RTS line. Please check out the screenshot attached below.
Regards.
Joris Vanderschrick
NIBE
(3,841 Views)
Sorry, I attached a file for .NET> The one below will be more usefull
(3,841 Views)
Joris, I installed VISA 3.01. It works fine in LV6.1, CVI 6.0 and the interactive VISA session from MAX. In CWorks I used the Serial and the VISA control, neither of of them could actually unassert the RTS line. They both reported 'read-only' property..
Thanks for the .NET version, I'll try it out tomorrow.
Jan
(3,841 Views)
