can i use visa.vi for rs232 to db25 port?
I'd love to see the new MOD.vi 69 KB that was attached to this email but am running version 7.  Any chance of getting a version I can see?
In any case, am I correct to assume that the visa vi CAN read correctly from a USB port whch has a USB to rs232 adapter on it?  Does LabView do this automatically?
Message 11 of 14
(1,064 Views)
@nivals wrote:
I'd love to see the new MOD.vi 69 KB that was attached to this email but am running version 7.  Any chance of getting a version I can see?,
Attached is the VI in LabVIEW 7. WARNING: You will get an "insane object" error when loading the VI. You can still load the VI. You will need to replace the chart with a fresh one. Delete the one that's there, and place a new one on the front panel. Downconversion sometimes doesn't handle charts correctly. FYI: in the future you can post downconvert requests in the Downconvert Requests Thread.
From LabVIEW's perspective it will simply see a serial port, since the drivers will be installed by the operating system, so it's handled at that level, not at the application level.
Message 12 of 14
(1,057 Views)
Knight of NI,
Thanks for the reply and the LabView 7 version of the block diagram.  However, it was for a sine simulator, not for a vi to read the input to the USB port (via an RS232 to usb converter).  Is it possible to get that diagram?
Thanks.
Message 13 of 14
(1,044 Views)
Your question makes no sense. The converted VI does have a VISA Write and Read from a serial port.
LabVIEW also comes with a serial port example VIs.
Message 14 of 14
(1,041 Views)
