bit
How to program individual bits in byte frame. Here I am using serial communication.
byte
bits
Element name
0
0
P3v3error
0
1
P3v3error
0
2
P3v1error
0
3
P3v5error
0
4
P3v3error
0
5
P3v3error
0
6
P3v3error
0
7
P3v3error
1
Spare 8 bits
Spare 8 bits
(3,480 Views)
Your question is far too vague, almost to the point of being meaningless. What is the context? In a serial communication you send bytes. What are you communicating with. What is your code? What message are you trying to create. If you expect an answer then please form a good question first.
(3,470 Views)
Assuming LabVIEW, you can typecast a U8 to a string. There is also the Byte Array to String.
(3,469 Views)
