beginners
I have recently begun using labVIEW, I am having problems linking to my DC power supply which is an ARGOS 500. I have created an instrument driver. When i run the application n error appears which informs me that the reason for this error is as follows:
VISA or a code library required by VISA could not be located or loaded. This is usually due to a required driver not being installed on the system
Since i created the instrument driver does the project not already contain the library. Also what other drivers would i require? do i need to downlaod plug and play?
Thank you
(4,065 Views)
You created the software layer, which consists of just the functions. You need the hardware driver layer. For that you need to install NI-VISA. You can download it from the NI site (click Support in the menu bar at the top), but it should also be on your installation discs.
(4,062 Views)
It is only the 30 day trial version at the moment until we purchase the licence, is there other drivers i require?
Thank you veru much
(4,060 Views)
For VISA that's all you'd need.
You did not indicate how you're physically connecting: serial, GPIB, TCP/IP. You would need the appropriate hardware driver for that particular interface, if necessary. For example, you'd need the GPIB hardware driver for a GPIB card. If you're using a serial interface card from National Instrument then you'd need NI-Serial.
(4,058 Views)
I am connecting serially, usb to rs32, yes i have the hardware driver for that.
(4,056 Views)
rs232!
(4,055 Views)
Before you get ahead of yourself, you might want to consider using a program similar to Hyperterminal to verify that you are able to communicate with the instrument. This will prove out your cable and your USB-serial device.
(4,047 Views)
