aggpib32controller.exe unhandled exception
When logging in to windows I recieve the following error:
AgGpib32Controller.exe - Common Language Runtime Debugging Services
Application has generated an exception that could not be handled.
Process id=0xa38(2616), Thread id=0xa2c(2604).
Click OK to terminate the application.
Click CANCEL to debug the application.
I am uncertain what causes the error and it is inconsistent as to when it comes up too.  Sometimes it comes up when you log in, other times it doesn't come up at all.  The error never comes up when running software nor does it interfere with the software or hardware performance (from what we can tell), BUT is an annoyance that I (in IT) would like to resolve so that the people I work with don't have to worry that their stations are going to explode or anything.
Brian
EDIT:
I forgot to mention that we are using the PCI-GPIB card in our systems and are running Windows XP SP2.  I am not entirely certain what software we use on these devices, but I can find out if it would be beneficial to resolving this issue.
Message Edited by Brian Gale on 05-02-2008 09:30 AM
(3,808 Views)
You need to go to www.agilent.com and ask about the problem with their software for their GPIB controller. That's assuming that you have an Agilent GPIB controller installed. If not, then their software should not be installed.
Message Edited by Dennis Knutson on 05-02-2008 08:32 AM
(3,804 Views)
thank you... sorry for being a bother like this, but the problem is a little annoying (in my mind).
But thanks for the reply and for directing me as to where to go to solve this.
Brian
(3,800 Views)
