XNET pallete or examples not available in LabView (2014)
Hey All,
Im trying to test some XNET controls to read CAN signals (NI-9862) but I cant seem to find any XNET palletes or examples for anything related to XNET in labView. I can see my 9862 device as well as the drivers for XNET. I have both NI-XNET 14.5 and NI-XNET Runtime 18.0 (which can be seen in MAX).
Could this be an incompatibility with the versions of XNET Im using and labView (2014, 32-bit on 64-bit machine)?
(2,533 Views)
Hi amas,
  • What is your operating system? I would check the Windows/LabVIEW compatibility. LabVIEW 2014 and XNET 14.5 are compatible
  • What order did you install software in? You should install LabVIEW => XNET. When installing XNET, in the configuration window, make sure you include support for LabVIEW 2014 through the first few windows.
  • Did you restart your computer as prompted after the installation?
  • How are you checking for the XNET functions/examples?
Best,
BDog
(2,500 Views)
Seems I had a 3rd party program that installed XNET before I installed LabView. Uninstalling XNET and reinstalling version 15 fixed the issue. Thanks for the support!
(2,494 Views)
