Write binary data to serial port
Hello. I am using PIC 18f to control my servo using USB. My PIC only reads binary data.
Therefore, I want to send binary data but seems like VISA WRITE only accepts string. My PIC does not recognize string.
Please assist. Thank you.
(4,463 Views)
A string does not mean the data has to be ASCII. As has been discussed numerous times, you can send the data in several ways. Right click on the string control/constant and select Hex Display, use the Byte Array to String, use the typecast function, etc.
(4,458 Views)
Thank you. 🙂
(4,442 Views)
