Why am I getting intermittant garbage measurements?
I am running some software that gets voltage and resistance measurements from a Tektronix 4054 O-scope. There is a function called DPO_GetMeasurement() in the O-scope code in CVI that is called into Test Stand every time it needs a measurement. There are different measurement types, etc., depending on what type of measurement it needs. However, regardless of what type of measurement it is performing, every once in a while, I will get this complete garbage number. Sometimes it will happen several times in a row, sometimes it won't happen but maybe one in ten tries.  It’s the same number every time: 99099999999999986303164714637431144448.0. I tried to decode it, in case it might be a term in hex or something, but to no avail. I scrounged around in the code and didn’t see it defined as an error code anywhere. I’m wondering if it might be a conflict between something in IVI Tools. I don’t know. Any suggestion would be of value. Thanks in advance.
(3,642 Views)
This is a very common problem in Tektronix measurement. Please include a necessary delay of few seconds before you use GetMeasurement(). It is needed for the instrument to respond. This will definitely solve your problem.
(3,613 Views)
Hello LMRoxy,
       Which IVI Specific Driver are you using?  Did you download it from IDNet?  If so, please provide the link.
NathanT
(3,601 Views)
What would be considered an appropriate amount of time? I forgot to mention that I had added a 2 second delay prior to the measurement, but was still running into the problem.
(3,600 Views)
Hi Nathan, it looks like the module I am using according to MAX is tkdpo4k_32.dll, IviDriver 1.0 & IviScope 3.0.
(3,599 Views)
I have a TEK DPO 4104 on my desk and I haven’t been able to reproduce what you are seeing yet. Can you post your code?
Matt
(3,553 Views)
