Where is IVI engine documentation?
I have the IVI Developers Guide and the help files that came with the sample IVI drivers. I can't find documentation for the IVI engine function calls like: Ivi_GetInfoFromResourceName. I want something that explains what each IVI Engine function call does and it's arguments.
(3,146 Views)
There are two methods that will provide the information you want.
First, use the Function Panels within LabWindows/CVI. From the menu Library --> IVI..., find the function you want (i.e. GetInfoFromResourceName). Then, open the function panel and right-click on the grey back ground for function help or on any control for parameter help.
Second, go to the LabWindows/CVI on-line help, menu item Help --> Contents. Use the index and enter Ivi. You'll see a list of all of the IVI functions and get access to their help pages.
--Bankim
(3,146 Views)
