10-08-2012 02:33 AM - edited 10-08-2012 02:35 AM
Hello everyone~
I am using the labview and the NI GPIB-USB-HS card to control the Agilent N8736 DC power supply.
The goal :I want to output the 24V voltage,then drop to 9V ,then rise to 24V ,the fall time and rise time shall be less than 10ms.
The question: how to assure the 10ms time?
I have download the Agilent N8736 GPIB driver from the NI web, and based on the model, I write the follow program listed in attach, and the test result is shown also.
I cannot assure the 10ms time, the actual test time was more than 300ms.
Thanks a lot~~
Solved! Go to Solution.
10-08-2012 09:55 AM
I would say: You can't achieve the <10ms with that powersupply. If you look into the specs (http://cp.literature.agilent.com/litweb/pdf/5990-3881EN.pdf) there are "output response times" and "command response times" much higher than your goal.
10-08-2012 10:02 AM
You may be able to get what you want with an extra power supply, a solid state relay, and a DIO that is hardware timed.
10-08-2012 07:28 PM
mkossmann:
Thankyou very much. I have read the instructions before, but cannot understand the output response time and command response time clearly. Now I see it, Thanks a lot~~~
10-08-2012 07:32 PM
crossrulz:
Thanks a lot. I will follow your advices and try other methods to attach my goal.
best to you~~
