Voltage Measurement Instrument
I'm looking for an instrument such as a voltmeter that can measure voltage drop across two points. I would like it to have an output I can connect to my computer so that I can monitor the voltage on LabVIEW.
Can anyone recommend an instrument for me?
Message 1 of 9
(6,316 Views)
Well, I have to get from point A to B, what do I need?  Answers can range from
-jump!
-just walk!
-boat?
-car?
-plane?
-rocket?
distance? needed speed? payload?
Same with your voltage measurement, please give more information, that may increase the number of helpful answers 😉
Range can be from ~40$ to >40 000$
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 9
(6,272 Views)
I need an instrument that can measure the voltage across two electrodes. The instrument and electrodes will be within a few meters of each other. The range of the instrument will be around +/- 20 V with a resolution of 1 mV. The price should preferably be less than $500.
Let me know if you need any more details.
Message 3 of 9
(6,262 Views)
How fast do you need to get the readings? Is there anything nearby (such as a speed-controlled motor or temperature-controlled oven) which might generate electrical interference? Does the instrument need a human-readable display or only computer interface? Do you have a preferred communications method to talk to the computer (Ethernet, RS-232, GPIB)? Do you already have any interface equipment to connect such communications methods to the computer?
Lynn
Message 4 of 9
(6,201 Views)
Lynn
I would like the unit to have a response time of less than 10 milliseconds. There is a small pump operating nearby. The instrument only needs a computer interface. I don't have a preferred communications method. The cheapest method is preferred. I do not have any interface equipment to connect to the computer.
Message 5 of 9
(6,196 Views)
OK. You probably should be looking at a 16-bit DAQ card or module. Most voltmeters, at least the inexpensive ones, have response times much longer than 10 ms at that resolution.
The USB-6002 and USB-6003 appear to meet the minimum specifications except for a maximum voltage range of +/-10 V.  Not very many DAQ devices have higher ranges than that.  You may need to put voltage dividers or other signal conditioners between your signal and the DAQ device.
Lynn
Message 6 of 9
(6,163 Views)
What accessories do I need to get in order to allow for voltage dividers or signal conditioning so that I can measure +/- 20 V?
Message 7 of 9
(6,109 Views)
You just need resistors for a voltage divider. Place them on a proto board. This is electronics 101.
Message 8 of 9
(6,105 Views)
And consider the myDAQ with its built-in dmm.
http://www.studica.com/mydaq
Message 9 of 9
(6,099 Views)
