Visa resource name does not appear in labview
I have a problem finding the visa resource name in labview. I am able to see the instrument on Max but when I use Visa I can not see it in drop down menu. How do I resolve this problem.
Thank you
(7,152 Views)
You aren't using an NI GPIB controller, are you? Have you done any of the recommended steps to make it visible, such as enabling tulip support?
(7,142 Views)
Thanks for the reply.
I am Using Agilent 82357B interface adapter controller.
How do I enable tulip support?
(7,141 Views)
passports for tulip is enabled
(7,135 Views)
And now nothing shows in MAX? I'm not sure what is wrong. If you still have have the problem after a reboot, I would suggest contacting Agilent.
(7,127 Views)
The instrument(Agilent N5181) shows in NI MAX and also in agilent connection expert. but when I try to program the instrument (test1.vi) it does not show in Visa resource list.
Thank you
(7,123 Views)
The last image does not show anything in MAX. Are the two versions of VISA compatible?
(7,117 Views)
