03-19-2012 11:01 AM
I use LV 8.6 to drive some equipements with VISA LXI, IVI and so one and I have a new digitizer to drive which requires Agilent I/O library. When I install Agilent I/O, the installshield find another version of VISA (NI's one) and ask me if I want to replace it by the Agilent's one.
I don't want to break my system (I want to continue to be able to drive my others equipements) but if I don't install the Agilent VISA, I'm not sure to be able to drive the digitizer with the Agilent softwares (MD1).
What is the best solution ? Can I replace the NI version or not? It is possible to switch dll file or change path location?
By advance, thanks,
Benjamin
03-19-2012 01:25 PM
You should be able to install Agilent as a secondary VISA, leaving NI-VISA as your primary VISA.
03-20-2012 07:29 AM
If I install it as secondary, is the "Agilent MD1 standalone software" and the "Agilent MD1 LabVIEW instrument driver" will work correctly ?
How can I ask to these apllications to use the secondary VISA driver instead of the primary ?
03-26-2012 08:31 AM
Is someone already did it and can tell me if it works. I have a lot af LabVIEW instrumentation programs on my computer and I don't want to break the configuration. For the moment I use 2 différents computers but is not convenient.
03-26-2012 08:52 AM - edited 03-26-2012 08:53 AM
I have both NI-VISA and Agilent IO Control 16 installed on my development desktop PC.
The Agilent VISA is secondary, and the NI-VISA is primary.
No problems.
