06-21-2006 01:26 PM
06-22-2006 07:13 AM - edited 06-22-2006 07:13 AM
@bknight04 wrote:
Hey everyone -I am very limited on electronic knowledge so I am sorry in advance for any confusion.[...]Bryan Bean
So I would suggest a digital output board with 16 relais with LabVIEW driver
You should provide some more information on the solenoids: Voltage and current needed
How many activ valves at the same time?
With a little help from someone with electronic skills you maybe can use the low priced USB 6501 with 24 digital IO. But you need some driver circuitry (one resistor, one diode, one transistor ...per channel and a power supply. Type and values depend on your valves.)
Edit: PS: Add one additional resistor and an optocoupler per valve, just to protect the USB device ![]()
Message Edited by Henrik Volkers on 06-22-2006 02:21 PM
