VISA write not working consistently
I'm using labview to send an ASCII character via serial port to trigger a PIC microcontroller to output a TTL pulse. It works the first few times I run the vi, but then it just stops working and I'm not sure what the problem is. I suspect it has something to with the VISA interface
The PIC is set for 2400 Baud and no flow control or terminating characters.
Any suggestions?
(3,181 Views)
There's nothing in the VI that would really cause it stop working. However, I would recomend that in your main VI, you actually call VISA Configure Serial Port once. No reason at all to call the property node over and over again. Just have a VISA Write in your subVI.
(3,172 Views)
