VISA timeout expired
I tried to use VISA read through a 485 serial port and got message "(hex 0XBFFF0015) timeout expired before operation completed. Please see attached VI.
Does anyone have any ideas how to connect VISA timeout VI to the original VI? Thanks,
(5,591 Views)
To All, I resolved issue.
(5,589 Views)
How did you do that?
I have the same problem ...
Thks
JP
(5,552 Views)
A timeout error occurs, for example, when a read operation does not complete before the specified timeout period. The read operation can fail to complete for the following reasons:
1. you did not receive the termination character you expected, nor the specified number of bytes to read in the timeout period specified. You may try increasing the timeout period, changing the termination character to one being used by the "sender" or decreasing the number of bytes you specify for your read operation
2. you are communicating at a sufficiently high baud rate without using termination and/or over a sufficiently long distance and/or in a sufficiently noisy environment that the actual frames which are being sent are not being received correctly. You may try using so-called "proper" termination and/or biasing on the network (see link below), decreasing the baud rate (at both ends since it must match for both communicating ports), decreasing the distance you are connecting over (unless this is very long, this is likely NOT the issue).
Link: http://www.ni.com/support/serial/resinfo.htm
If you are still having problems feel free to repost!
Best Regards,
JLS
Best,
JLS
Sixclear
(5,535 Views)
HI
I have been using a Pulnix TM1040 and a frame grabber PCI-1422 of NI for a while. Before they all ran well but now, when grabbing, it showed a dialog:"IMAQ error: the serial read didnot complete within the specified timeout period". I have downloaded the camera file from NI but the sesults were the same.
Does anyone know about this problem, please help me. I need to fix this as soon as possible for my experiment because now I am running out of time.
If you can, reply one more to my email: nguyenhk@aero.pauir.itb.ac.id
Thank you very much.
(5,243 Views)
