12-29-2006 01:51 PM
01-02-2007 10:23 AM
First I would like to ask you a few question about your program. I see that you have declared your GPIB and ManualGPIB. What class is this declared as? Once I know what the class is I should be able to help you set the timeout.
Also, it seems like you are using VISA so you could run your program with NI-SPY running and this will help us narrow the code down to where the actuall issue is accruing. To do this go to Start>>Programs>>National Instruments>> NI SPY and select that program. Then select the blue arrow to make NI SPY run. With this running please run your program. Then save the NI SPY file and attach it to your next post.
The answers to both of these question will allow me to help you better. Thank you.
