cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
VISA Serial Write Corrupt Data on Win98
I have isolated the problem from my application by comparing results of VISA communication with results of Hyperterminal.
I have two computers that behave differently. One runs Win2K, the other runs Win98. Both are running VISA 3.0.1. Both are communicating through NI-PCMCIA-485 port in 2-wire txrdy mode.
To recreate the problem, I connected the two serial ports together, then send messages back and forth, sometimes using MAX and VISA, and sometimes using Hyperterminal.
I find that messages sent with Hyperterminal from either machine are correctly received by either Hyperterminal or MAX/VISA on either machine. Also, messages sent with MAX/VISA on the Win2k machine are correctly received by either Hyperterminal or MAX/VIS
A on the Win98 machine.
However, messages sent with MAX/VISA from the Win98 machine are not correctly received by either software on the Win2k machine. My conclusion is that VISA WRITE under Win98 is corrupting the data.
Specifically, the final transmitted character is changed. For example, data string d01tpos\r is changed to d01tpos\xFF. If I double-up the string, d01tpos\rd01tpos\r becomes d01tpos\rd01tpos\xFF. So it is not the carriage return character specifically causing the problem.
It is not always the final character, either. At one point I sent "Hello VISA MAX." but received "Hello#VISAOax\xff"
I would appreciate some help with this problem. I have a Labview 6.1 application that I developed on a Win2k machine that works fine, but I wish to deploy it to a Win98 machine and it does not work because the strings are not being properly transmitted.
Thanks.
Jim B.
Mensagem 1 de 3
3.463Exibições
Jim,
I am wondering if you are having a problem with biasing. Have you set up any bias resistors on your 485 network? The following knowledge base explains the need for bias resistors on a 485 network:
http://digital.ni.com/public.nsf/websearch/12BB6CD900B2D0EF862564980050F5A7?OpenDocument
I'll continue to look into other possible causes.
Craig H.
NI Applications Engineering
Mensagem 2 de 3
3.463Exibições
No. But the fact that Hyperterminal communicates flawlessly suggests that network biasing is not a problem.
-Jim
Mensagem 3 de 3
3.463Exibições
