VISA Serial Communication Problem
Hopefully someone can help.  I am trying to use Labview to send commands and receive information from a Ludl Electronics MAC-2000 microscope stage.  I am trying to use the example Basic Serial Read and Write VI.  I know that my serial port is working because I have conducted a loop test by shorting pins 2 and 3 on the 9 pin connector.  What I type in the “string to write” window matches the “read string” window.  I know the microscope stage works because when I type commands into Windows HyperTerminal, the stage responds appropriately.  However when I type the same commands into Labview (string to write), and run the VI, nothing happens (the microscope stage doesn’t respond).  The program simply times out.  I checked the return count of the VISA Write, and I get the correct count of bytes “written”, but the microscope stage doesn’t respond.  I think there is a handshake problem with Labview since HyperTerminal works, but I don’t know what the problem is.  Any help would be greatly appreciated.
Tim Taulbee
(3,789 Views)
Dennis Knutson solved this problem in another post on Serial Communication.  My problem was that when I typed a commaned, the end of the string had a \n (linefeed) where the instrument was looking for a \r (Carrage return).
Thanks again Dennis!
Tim
(3,784 Views)
