02-07-2012 03:54 AM
I need to connect a Mac-mini (OS-10.6.8 in Bit) with a Medical Monitor Philips MP20. I wrote the software using LabView 2009 and VISA 5.1.1. I am using a serial to USB convert port from VS-COM company.
The manual of monitor command to make first an association between the server (medical monitor) and the client (Mac mini). This operation works very well. Then, I set several parameter to the monitors and works very well. When I begin to get data from Monitor, for example Demographic data of patient, start problem like latency between the request msg from Mac mini and the response of the monitor; I get the Error -1073807339 ( I found this link to solve the problem http://digital.ni.com/public.nsf/allkb/874B379E24C0A0D686256FCF007A6EA0 , but no works).
If I run the same VI en a Mac mini with Os 10.5.8, works without any problem. But We want it to work with Os 10.6 or higher! Can you help me with this issue?
02-07-2012 05:10 PM
According to NI's web site VISA 5.1.1 is still in beta testing. 5.0 is listed as compatible with 10.6.8. Can you try that?
I have VISA 5.1.0 on my computer. I got it when I bought LV 2011 last fall, but I do not see a 5.1.0 version listed on the web site.
With all the local variables you may have a race condition in your program. This could cause the program to work on one machine and not on another.
Lynn
