10-02-2019 12:48 PM
I am running into a very difficult issue using the VisaNS library in C# .NET. I have created a class called FactoryInterface with the following constructor:
public class FactoryInterface : ICommonControl
protected MessageBasedSession _mbSession;
public FactoryInterface(string com_port)
SerialSession ss;
_mbSession = new SerialSession("COM14");
ss = (SerialSession)_mbSession;
ss.BaudRate = 57600;
ss.DataBits = 8;
ss.StopBits = StopBitType.One;
ss.Parity = Parity.None;
ss.Timeout = 1000;
ss.TerminationCharacter = 0x0d;
I then create an object of Factory interface and call the following function, SendCommand with the parameters "get netconfig\r" and false:
public void SendCommand(string cmd, bool getError)
{ _mbSession.Write(cmd + "\r"); }
Which returns the following exception:
Unknown system error (miscellaneous error). VISA error code -1073807360 (0xBFFF0000), ErrorSystemError
In order to test the device I open VISA Test Panel. I configure the device with the same parameters as above and send the same string. The write completes without error.
When I capture both communications using NI I/O Trace, I see the following descriptions for the successful and unsuccessful communications, respectively:
2. viWrite (ASRL14::INSTR (0x00C7DA10), "get netconfig.", 14 (0xE), 14 (0xE)) Process ID: 0x00005530 Thread ID: 0x000052C0 Start Time: 10:11:58.1070 Call Duration 00:00:00.0002 Status: 0 (VI_SUCCESS)
> 27. viWrite (ASRL14::INSTR (0x00000001), "get netconfig.", 14 (0xE), 0 (0x0)) > Process ID: 0x00005404 Thread ID: 0x0000569C > Start Time: 10:12:32.8867 Call Duration 00:00:00.0000 > Status: 0xBFFF0000 (VI_ERROR_SYSTEM_ERROR)
Any insight or lines of investigation would be greatly appreciated.
Thank you for your time.
10-03-2019 12:41 PM
_mbSession is protected variable in the class FactoryInterface
Is SendCommand a member of the FactoryInterface class? I can't tell with the code snippet.
10-03-2019 12:46 PM
Yes, SendCommand is a member of FactoryInterface.
10-03-2019 12:48 PM - edited 10-03-2019 01:39 PM
This is not the only com port device which I am connecting to through the VISA library. I have notice that my failure disappears when I do not connect to my Korad power supply, and the failure returns when I am connected to the power supply.
I should say that not connecting to the power supply is not an acceptable workaround. I need to be able to connect to both the power supply and the factory interface at the same time.
10-03-2019 03:52 PM
I am not sure how having another instrument is relevant.
Only one instrument can be connected to one serial port.
10-03-2019 05:14 PM
I narrowed down the relationship to the power supply. In a setup routine, a FactoryInterface object is created. Then, the power supply is used to power cycle the device which is connected through the FactoryInterface object. After the device is powered up, I send it a command. This communication is where the error occurs. The error does not occur if no power cycle is done.
So my follow up question is: how does power cycling a device which has a live serial connection disrupt the serial connection? Do I have to "close" the connection before powering off the device, then "open" the connection after it is powered up? This is the experiment I will try next.
