02-10-2012 03:07 AM
Hello everyone,
Basically i have 2 VIs, one running on a PXI, lets call it PXI.vi and one on the pc, GUI.vi
I started testing my application some days ago and after 3 hours of running i got the error in the picture.
Error -1073807339 occured at VISA Write in PXI.vi
Reason: "Timeout expired before operation completed."
Then immediately also this error:
"Unable to locate variable in the shared variable engine. Deployment of the variable may have failed."
I restarted the PXI and started the test and it happened again after 2 hours.
The third time even sooner.
It is always 2 variables that cause this problem.They are used to pass information about error happening on a instrument.
So actually they are not even used when giving the message.
I check them in a loop every second.
They are not buffered. I initialize them when the vi starts
I am using Labview 2011 and windows 7
Thank ou in advance for your time.
Solved! Go to Solution.
02-27-2012
03:49 AM
- last edited on
11-17-2025
09:14 AM
by
Content Cleaner
I guess you have already checked those links, which explain the source of your errors:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAQKSA4&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019M1mSAE&l=en-US
http://digital.ni.com/public.nsf/allkb/F28F3B9E82BF7498862571E2007D615F?OpenDocument
If that's ok by you, you could also upload your code so we can take a closer look at it.
Regards
02-28-2012 06:55 AM
Your third link was right on the spot.
I accidently deleted one "\" from the data path of the variable and was causing the error.....
Thank you very much.
02-28-2012 06:59 AM
Glad to help!
Have a nice day!
