Unable to find the device I want in NI-MAX
I have installed RFSG, RFSA, and RFMX drivers, but I cannot find VST devices such as 5644R, 5645, 5646, and 5820 in NI-MAX. Before that, after installing NI-Switch or NI-Power drivers, I could find corresponding simulation devices to test, such as 2543 and 4132
Message 1 of 10
(1,988 Views)
Nope, not all devices can be simulated.
RF devices typically do not support simulation device under NI MAX unless you have an STS config and TSM.
Santhosh
Soliton Technologies
Message 2 of 10
(1,984 Views)
Is STS config and TSM another set of software that requires payment to download and use
Message 3 of 10
(1,977 Views)
Typically, customers buy NI RF STS and along with this expensive equipment comes the softwares and features to help them develop and test code offline using Simulated instruments.
https://www.ni.com/en-in/shop/electronic-test-instrumentation/what-is-the-semiconductor-test-system....
https://www.ni.com/docs/en-US/bundle/teststand-semiconductor-module/page/tssemiconductor/tssemicondu...
Santhosh
Message 4 of 10
(1,912 Views)
Alternatively, you can simulate the device at the driver layer by providing an 'option string' at initialize as described in this article,
https://www.ni.com/docs/en-US/bundle/ni-rfsg/page/rfsg/simulate.html
Santhosh
Message 5 of 10
(1,909 Views)
Thank you,santo;
I have simulated VST sending and receiving by adding optionString;
But I want the Marker function of the vector signal analyzer, as well as displaying the X and Y coordinates, similar to the function on the Soft Front Panel. However, the method on. Net seems to be missing, and only one column of PowerSpectrum can be read. What I want is two columns, the first column represents dbm, and the second column represents the corresponding frequency, but I haven't found it yet.
Thank you very much!
Message 6 of 10
(1,834 Views)
Photo attached
Message 7 of 10
(1,833 Views)
Accepted by topic author JackLinze
@JackLinze wrote:
Thank you,santo;
Simulation is not 'emulation', the driver does not fully emulate the device instead it returns dummy data. May be it is not part of the simulated feature of the driver.
Santhosh
Message 8 of 10
(1,799 Views)
Yes, I simulated it on my own computer, and the above situation was discovered in a laboratory with 5644 devices; With. NET, only the power spectrum can be read, and there is no one-to-one correspondence between frequencies. I want to draw a curve plot based on the read power and frequency under. NET;
Message 9 of 10
(1,782 Views)
Thank you,santo_13;
I think I have solved my problem. I have mapped the power one by one through the NumberOfSpectralLines, InitialFrequency, and FrequencyIncrement of RfsaSpectrumInfo. Thank you
Message 10 of 10
(1,744 Views)
