Unable to connect GPIB-USB-HS to GPIB-ENET/100 (EBUS Error)
Hi!
I'm new to GPIB and have just bought a GPIB-USB-HS and a GPIB-ENET/100. I would like to send data from the USB-device and read the data with the ENET/100-device. Both the GPIB-USB-HS and the GPIB-ENET/100 is found by the Measurement & Automation Explorer. How do I configure the ENET/100 so that the GPIB-USB-HS finds it as an instrument? I want the USB-device to be a system controller and the ENET/100 a listener.
When using the Interactive Control the first ERROR I get is EBUS when using the ibwrt "*IDN?", return count is 0.
Jonlof
(3,084 Views)
Problem solved. The main error that I did was connecting the two devices to the same computer, because of that the devices got different board-IDs. When using two separate computers I managed to send data through the devices.
(3,071 Views)
