USB to Serial stops responding after using NI-MAX
@Dennis_Knutson wrote:
Let's take one step back. Exactly what happens when you try to communicate with MAX? Please provide some details as saying 'doesn't work' is insufficient. What command? What error code/message?
Timout expire
When I send a command, I don't get any answer. And I do believe that all my port setting are correct.
Message 11 of 23
(3,233 Views)
You aren't sending any termination character(s). Do you have a manual? Does it say to append a cr, lf, or both? Have you tried a program such as putty?
Message 12 of 23
(3,228 Views)
Doesn't need any termination character according to the manual.
Here is a screenshot send to me by the manufacturer that show that it's working there.
Message 13 of 23
(3,226 Views)
It's certainly returning cr/lf. I still recommend a third party program to see off the problem exists there.
Message 14 of 23
(3,222 Views)
The instrument is returning a CR/LF, but the write shows only just *VER.
Message 15 of 23
(3,212 Views)
I know but you can also use a VISA property to automatically append a termination character and this setting is not known. It's unusual for an instrument to respond with cr/lf and not need it for a read. I'm mostly curious about a communication program other than the vendor's and that does not use VISA.
Message 16 of 23
(3,210 Views)
From the manual:
USB & ETHERNET communication Bits per second
921600
Data bits
8
Parity
None
Stop bits
1
Flow control
None
In the HyperTerminal window type *VER, press  ENTER. If the response you receive tells you the version of your S-Link, you are successfully connected and ready for serial command action.
I did that, I didn't get any answer from the device.
Message 17 of 23
(3,207 Views)
That says a lot. Hyperterminal automatically appends a cr/lf. Since you don't get a response, that points to some problem with the device.
Message 18 of 23
(3,205 Views)
New development here.
I tried it on my personnal laptop and everything works great. Software, VISA, hypertem.
So the problem seems to be with the computers at work. I tried on three of them, on which I have admin rights, without any luck.
And the IT guys don't seem to have any clue...
Well...
Message 19 of 23
(3,196 Views)
You've never mentioned which os you are using. What is the ftdi version?
Message 20 of 23
(3,194 Views)
