USB examples with VISA 3.0
Does anyone have any examples of communicating with a USB device using NI-VISA 3.0, using a driver created with the VISA Driver Development Wizard? Either LabVIEW or C, or even just using VISAIC.
Using C or VISAIC I can get/set attributes, get the status from the endpoints using USB Control In, but when I try to use viWrite or viRead to communicate with the device firmware I get error 0xbFFF003A ("Unable to start operation because setup is invalid").
Any ideas or examples would be very useful!
(3,537 Views)
Hi.
I'm guessing you should use the RAW class, and not ordinary VISA READ/WRITE.... I was hoping you might be able to help me a bit? I'm currently working on a project with a custom made USB device myself. I am having problems using the interrupt endpoint. VISA seems unable to detect my Interrupt endpoint, and reads status -1. This is not the case if I use Bulk endpoint. Seems strange, since VISA supposably supports interrupt... Any tips?
(3,536 Views)
