USB Webcam with Control
I just purchased a USB videoscope from here: http://www.fiberscope.net/servlet/the-56/USB-Video-Borescope%2C-usb/Detail. The videoscope has a camera at the end of the tube and two buttons on the handle to control whether to capture an image or record a video - This is using the supplied program. My first goal, which is to capture the images using LabVIEW, is a success using the NI's USB-IMAQ driver. The next task that I need to do is to include the functions of the two physical buttons into my program. I'm currently playing around with USB Raw thingie but am not sure whether I am doing this correctly (ie. reading the images using USB-IMAQ and reading the status of the buttons using USB Raw). I read somewhere that if I need to take this approach (using USB Raw), I need to know the protocols (commands) used by the manufacturers - this is something I do not have. Any suggestions?
Inputs are very much appreciated!
Shazlan
(4,053 Views)
I am not very clear about  the above statement.Can explain it more clearly .Can you attach a block diagram of your vi that you have tried?
What do you exactly mean by two physical buttons? what should it do? what do you mean by "thingie"?
(4,046 Views)
Post vision,Camera and IMAQ realted stuff in machine vision section.You will get a better hit rate.
(4,042 Views)
Hi Muks,
Thanks for your reply. Please refer to the attached image - Sorry, I do not have a better view as I left the videoscope in the office. On the handle of the videoscope, there are two buttons - A & B. These buttons act like a trigger. If I were to use the supplied program, it will automatically save the image (still picture) once I pressed button A. On the other hand, the program will start to record in video mode once I pressed button B.
I've managed to communicate with the camera using LabVIEW's USB IMAQ driver - my program can see what the camera sees. What I want to do now is to monitor the two buttons and replicate what it does as mentioned above. I've followed through the tutorial here (http://zone.ni.com/devzone/cda/tut/p/id/4478).
1. It mentions that a USB instrument can be classified into two categories: USBTMC and USB Raw. My question: How do I know which classification does my instrument fall into? For now, I assume that it falls onto USB Raw. How can I verify?
2. If my assumption on USB Raw is true, the article goes on and says that I need to "contact your device vendor for details about the communication protocol for your device". So far, this is not a success. What do I need to do to proceed?
I hope that this explanation is clearer. Please advice.
(4,027 Views)
