Thermocouple measurements insists in using "Fixed Reference Junction" - AG34980A
I'm trying to read some thermocouples from an AG34980A with 34921T terminal block using Labview 2018. I'm using the "AG34980A Configure Thermocouple.vi" to configure the channels to read Type-T thermocouples with the "internal" reference junction. But when I read them using the "AG34980A Measure Thermocouple.vi" it changes the reference junction back to "Fixed" and gives me wrong results.
I opened the "AG34980A Measure Thermocouple.vi" and it is sending this command: MEAS:TEMP? TC,T,DEF,(@1001:1040,2001:2020). In the past I used exactly this VIs to measure thermocouples using AG34980A and it always worked (LV2014).
I posted this same question at Keysight community: https://community.keysight.com/message/95539. If I have solution there I'll post it here also.
PS: this VI's came from the Labview Drivers supplied from Keysight for this instrument and are not supported by National Instruments.
(1,202 Views)
In order to verify if there was any difference between the messages sent by the old application and the new one I traced it using the NI I/O Trace and it seems that it is writing the same message, but reading different results.
LV2012 Application:
1. viWrite (GPIB0::9::INSTR (0x037DBD70), "MEAS:TEMP? TC,T,DEF,(@1001:1040,2001:2014)", 42 (0x2A), 42 (0x2A))
Process ID: 0x000027F4 Thread ID: 0x0000277C
Start Time: 14:25:59,0539 Call Duration 00:00:00.0019
Status: 0 (VI_SUCCESS)
2. viSetAttribute (GPIB0::9::INSTR (0x037DBD70), 0x3FFF001A (VI_ATTR_TMO_VALUE), 10000 (0x2710))
Start Time: 14:25:59,0559 Call Duration 00:00:00.0009
3. viRead (GPIB0::9::INSTR (0x037DBD70), "+2.42220000E+01,+2.42700000E+01,...-3.42570000E+01,+9.90000000E+37.", 1024 (0x400), 864 (0x360))
Start Time: 14:25:59,0569 Call Duration 00:00:02.3962
Current Application:
1. viWrite (USB0::0x0957::0x0507::MY44005022::INSTR (0x00000002), "MEAS:TEMP? TC,T,DEF,(@1001:1040,2001:2020)", 42 (0x2A), 42 (0x2A))
Process ID: 0x00001F50 Thread ID: 0x00001FF8
Start Time: 14:29:33,1212 Call Duration 00:00:00.0007
3. viSetAttribute (USB0::0x0957::0x0507::MY44005022::INSTR (0x00000002), 0x3FFF001A (VI_ATTR_TMO_VALUE), 10000 (0x0000000000002710))
Start Time: 14:29:33,1220 Call Duration 00:00:00.0000
4. viRead (USB0::0x0957::0x0507::MY44005022::INSTR (0x00000002), "-2.06500000E+00,-2.02900000E+00,...+9.90000000E+37,-1.66800000E+01.", 1024 (0x400), 960 (0x3C0))
Start Time: 14:29:33,1220 Call Duration 00:00:02.6601
(1,158 Views)
Accepted by topic author FBro
Problem solved. I don't know exactly in which step I did fix it so I wrote down all the steps I made.
  1. I uninstalled the NI-VISA 20.0 from the application PC, because the the NI-VISA from the developer PC was the 18.5;
  2. The uninstallation wasn't successfully done. When I tried to install the NI-VISA 18.5 it kept saying that I had a higher version already installed. So I had to manually remove the NI-VISA 20.0 from the Windows Register.
  3. I've installed the NI-VISA 18.5, but a message saying that the VISA .NET 5.5 wasn't found appeared during the installation so after installing it I did a "repair" using the Package Manager in order to complete the installation.
  4. After all that I've compiled a new version of the application, which still was getting me the wrong thermocouple values. Then I started to recompile the application to prior Labview values, because I realized that an older application with different features was actually reading it right. The recompilations also didn't work.
  5. I downloaded the Agilent AG34980A 2005 drivers and recompile the version using it.
  6. Revised the whole data acquisition code and realized that during one of the above steps I inserted a "reset" before reading the thermocouples. I recoded it and finally it worked, although I don't know exactly in which step it started to work... One thing I'm sure is that the first code was correct, because I returned to that version.
I'm completing the circle here because maybe someone can benefit from this information in the future.
(1,154 Views)
