Themrotron Labview Driver Error
Hi I am using the most recent Labview Driver from Thermotron for the 4800 Controller (Not the IVI driver). I installed it as per there directions. I get the following error code -1074135040 . Since it happens with initialization sub vi. I cannot proceed further and can find no reference to define the error. I can communicate with the chamber over the MAX AUTOMATION stuff. So I don't think its a hardware issue. Anyone know the erro code definitions? Or have experience using this driver. I am running labview 8.0.1.
(3,833 Views)
(3,814 Views)
So that error code say's I don't have the VISA stuff installed correctly. When I go into max automation it shows that I have NI-VISA 3.4. I was told to copy the TH4800.DLL to vxipnp/bin directory. The only thing I can think of it doens't know the DLL is there or it can't find ti. I am looking into the other stuff too. Thanks If you have any other ideas let me know
(3,807 Views)
Turns out I didn't have the IVI compliance package installed which lauches the IVI runtime engine....Problem Solved thanks
(3,795 Views)
