The IVI Driver from idnet dont add itself into Configuration Store
I am a novice user of IVI driver.I have some problems while installing the IVI driver from idnet. While referring to The IVI-3.17_Installation guide, Section 2.3.1 states, "An IVI-COM/IVI-C driver installation program installs the driver files to standard directories, creates Windows registry entries for the IVI-C or IVI-COM driver, registers the driver with the IVI configuration store, and registers an uninstaller for the driver." I believe that the step of "registering the driver with the IVI configuration store" is necessary. However, when I install the driver from idnet, I only see a few files. I cannot find the installed driver in NI-Max, and there is no information in the IviConfigurationStore.xml file. Is there something wrong with the installation process?I have tried idnet-agn9310ni-ivi_1.3_online.exe and idnet-tkdpo4k-ivi_4.6_online.exe.包管理界面.jpg
The Tkdpo2k3k4k driver in picture is from other verdor ivi driver installer.
Message 1 of 1
(1,135 Views)
