Thank you for the fast response! error message is .....
Dear Ni user,
thank you very much for this fast response?
I have attached here my code and error message. I am very greatful if somebody help me to get out of this problem.
Thanks in advance
Jstin
(3,804 Views)
Do NOT start a new thread! Respond to the original.
A query interupted usually means what it says. You start a query and send a command to the instrument at the same time (or before the instrument has a chance to completely reespond). You did not attach your program. You only attached some image (and why would you create a pdf of it?). If you are doing something else in parallel, don't. You would also want to give the instrument time to finish resetting. Try doing just the read in MAX and seeing if it works.
(3,796 Views)
duplicate thread
http://forums.ni.com/ni/board/message?board.id=140&thread.id=37932
Please don't ask the same question is several threads, keep it to one thread
greetings from the Netherlands
(3,794 Views)
