Tektronix TDS 3032B serial port
I am trying to acquire data from a Tektonix TDS 3032 via a serial port, I have downloaded the drivers from here:
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=014E9F890ACE6DA0E0440003BA7CCD...
I have connected the scope to LPT1 (is this correct?) on my PC with a 25 pin serial cable when I run the VIs in the project that come with the drivers it gives me the following error:
Error -1073807302 occurred at VISA Clear in Tektronix TDS 3000 Series.lvlib:Clear.vi->Tektronix TDS 3000 Series.lvlib:Initialize.vi->Tektronix TDS 3000 Series Single Channel Waveform Acquire.vi
Possible reason(s):
VISA:  (Hex 0xBFFF003A) Unable to start operation because setup is invalid (due to attributes being set to an inconsistent state).
I feel that I am missing something fundamental, but can't work it out.
Many thanks,
Jack
(4,076 Views)
Jack,
LPT1 is a parallel port.  You need to be using a serial port on your PC.
(4,069 Views)
