TNT4882 in an 8051 Based system
Hi!
I'm a student, designing a GPIB device using TNT4882 chip. I'm using NI's application note 077 (link no longer available)
I was wondering if it's possible for someone to explain how is CSN (Chip select) signal generated.I see that PSEN and most significant bit of the address are used along with NAND whose inputs are inverted(I think that is OR), but I don't understand why it is done like that.
Thank you!
(3,608 Views)
The CSN pin on the TNT4882 is the chip select pin. This pin must be asserted (driven low) during a register access to the TNT4882. The purpose of a chip select pin is to allow multiple devices to occupy the same address space and be able to uniquely address them. Whenever RDN or WRN is asserted, and CSN is asserted, the TNT4882 interprets this as a register access. Asserting RDN or WRN without CSN asserted will be ignored by the TNT4882.
The exact implementation of the CSN pin is unique to each system. The most common method is to connect it to an address pin beyond the range of what the TNT4882 uses. For example, the TNT4882 uses 5 address lines. If the host microprocessor has 10 address lines, the 6th address line could be connected to the CSN input of the TNT4882 through an inverter. In this case, whenever the TNT4882 is accessed, the 6th address bit must be driven high, to cause the inverter to drive the CSN signal low. Accesses to other devices must be made with the 6th address bit low which will drive CSN high.
If all accesses on the interface bus will be to the TNT4882 (no other internal or external devices) it is possible to tie CSN directly to ground. If you do this it is still advisable to provide some external circuit for asserting CSN even if it is not used.
In the example you mentioned, PSEN is a chip select signal for an external EEPROM. The circuit will assert CSN only when PSEN is unasserted (high) and address 5 is low. In this circuit address 5 must be low to access the TNT4882.
(3,605 Views)
Thank you very much for your answer!
Best regards.
Mirna
(3,589 Views)
