Synchronize GPIB with Analog input
I am using GPIB to control my Agilent 33250A function generator in order to generate an arbitrary waveform. Also, I would like to sample a digital signal via analog input that is synchronized with the arbitrary waveform. If I use Labview to program, how do I synchronize those waveforms?
(3,354 Views)
I believe I just contacted you via Email with a response to your question. If you would like to continue your support request with myself, then please continue to use the email that I replied with. You may still try and post your question on the developer forums if you would like.
Also, I was able to find an older discussion forum thread which was related to your question. You may like to have a look at it:
GPIB Synchronization with DAQ.
Jared A
(3,354 Views)
