Startech Windows 7 64 bit Issue
Hello all,
I have a Startech.com PCIe RS 232 Serial adapter card (PEX2S553). When using this card on a 32-bit Windows XP machine I can read and write data with no issue. (2.3 MB  at 300 bytes per second. No read or write fails.) When I install this card on any Windows 7 64-bit machine it will run for anywhere from 30 seconds to 2 minutes and then the write will time out. Solutions tried so far with the same results:
2 different Windows 7 machines
Verified the 6- bit drivers were installed.
Vairous baud rates (38400 default)
Various time in between writes (3 bytes at 100Hz typical)
Various timeouts (15ms up to 150 ms)
What I don't have is a 32-bit Windows 7 machine to try this card out on so I am have trouble deciding exactly what the issue may be. Has anyone else seen similar issue with Startech products?
(5,483 Views)
@John1994 wrote:
Hello all,
What does Startech have to do with National Instruments????
Go talk to them.
(5,478 Views)
Go talk to them.
I have also tried compling the executables using NI LabVIEW 2014 64-bit with the latest device drivers and NI VISA 14.0. Since I am trying to use this card via a LabVIEW application I thought it was worth a quick check.
Thank you for the advice nyc. I never would have thought to contact the manufacturer without your helpful tidbit of information.
(5,473 Views)
