Simulate a GPIB device controlled by VI as GPIB controller using the GPIB-USB-B.
I would like to find an example that uses a VI to listen on the GPIB buss and simulate the response of a device controlled by a VI acting as GPIB controller.  I have a GPIB-USB-B to communicate over the GPIB buss.
(3,198 Views)
Hey Tri_State_Port!
How are you doing?  I found the following example for you.
"This example shows how to use a GPIB board as a non-controller to simulate a GPIB instrument in LabVIEW. In "non-controller.vi", the GPIB interface is configured to be the non-controller and is assigned a primary address. The VI then waits in a loop to receive a message from the controller (using "controller.vi") and sends a response back."
http://zone.ni.com/devzone/cda/epd/p/id/5323
Hope this helps!
Best Regards,
Song Mu
National Instruments San Diego
(3,183 Views)
