SetConfiguationOption
Hi all,
I'm trying to disable serial polling on my interface.
I need to do this in VISA but long since realised it's not possible. I need IBCONFIG but this command is not supported with .NET.
I have located what I think is the .NET alternative 'SetConfiguationOption'
NI 488.2 Documentation "Mapping the NI-488.2 .NET API to the NI-488.2 C API" shows 'SetConfiguationOption' mapped to 'IBCONFIG'
The specific reference can be found here:- http://zone.ni.com/reference/en-XX/help/370628F-01/mstudiowebhelp/html/gpibapimapping/
The documentation also notes that this function is located inside the 'NationalInstruments.NI4882' library and there's my dilema!
I cannot found the 'SetConfiguationOption' method inside the 'NationalInstruments.NI4882' library. Am I missing the plot? or it's located somewhere else?
Any help greatly received 😄
Br
Nigel
(5,396 Views)
Hi Nigel,
The "SetConfigurationOption" method can be found under the 'Board' class as stated in the linked article. To access it; when you are placing your .NET Constructor Node follow these steps:
1. Select the NI4882 library in the Assembly menu
2. Select "Board" in the Objects menu
3. Select "Board()"in the Constructors menu
4. Click OK
From here you can right click on the reference output of the Board Constructor Node and navigate to and select Create»Method for National Instruments.NI4882 Board Class»SetConfigurationOption as shown in the attached code snippet.
I Hope this helps, if you have any other queries, let me know.
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(5,365 Views)
Thanks for the thorough reply Tim.
Much appreciated! although I think I missed stating the fact that I am attempting to do this in C# .NET and not Labview.
I can get into the Board class but there is no 'SetConfigurationOption' method available inside the C# board class.
Many thanks again for your time.
Nigel
(5,357 Views)
Hey Nigel,
Are you using NI Measurement Studio?
How are you looking for the "SetConfigurationOption method", is it something like this
Can you access other methods in the class/ library?
I think these posts could also be useful:
http://stackoverflow.com/questions/4023462/how-do-i-automatically-display-all-properties-of-a-class-...
http://stackoverflow.com/questions/5475209/get-class-methods-using-reflection
Tim, CLD, CTD
(5,278 Views)
