Serial
Okay, here is part of the manual. On page 33 of the PDF there is another packet that has so error fixes I believe. There is one more packet like that, of error corrections, but I don't have it with me right now. I can upload it later on if you think we need it.
-K
Message 11 of 43
(2,150 Views)
Well, that is the generic format of a single packet. I'm not sure whether that is a read or write packet. It's clear that you will have to work in hex in order to send the correct sync codes, calculate the checksum, etc.
Message 12 of 43
(2,148 Views)
does labview accept hex as a string?
-K
Message 13 of 43
(2,145 Views)
You mean VISA. You can simply right click on a string control/constant and select Hex Display. You can also create a U8 array and use the Byte Array to String function. You can also use the Typecast function.
Message 14 of 43
(2,140 Views)
Is there a way to put muliple data entries of hex into the same string line? because I'm pretty sure that the code I need will have to be multiple characters all as a single command. or do I need to just do it each individually and set it up as one large  VI?
-K
Message 15 of 43
(2,135 Views)
Of course you can have multiple characters in a single write. You were doing that with your writes to that GPIB instrument you were playing with. Totally irrelevant if the characters displayed are ASCII or HEX. They are just bytes being sent.
Message 16 of 43
(2,131 Views)
well when I changed it to hex it would not let me put spaces or press enter to distinguish between a different data entry.
-K
Message 17 of 43
(2,128 Views)
That is a slightly different question. Typically, for multiple entries/discrete commands, you would have a write for each. This is easily done with the Write inside a for loop and passing in an array of commands. Also, a carriage return/line feed/space are distinct hex characters and you would typically not randomly place them where you wanted. The instrument would not intrepret them as separators but as data (and invalid data at that).
Message 18 of 43
(2,122 Views)
Ok, I am still confused as to how I can draw out what I need from the maual in order to get a comand to work in Labview.
-K
Message 19 of 43
(2,109 Views)
nevermind
-K
Message 20 of 43
(2,081 Views)
