Serial port ctrl.vi
I seek one VI which corresponds has "serial line ctrl.vi" which is compatible with LabView 6.0
(3,724 Views)
For LabVIEW 6.0 and later, the functionality implemented in the Serial Line Ctrl.vi is available through a VISA Property Node.
The property node can be found in the following palette:
Functions Palette>>Instrument I/O>>VISA>>VISA Advanced
Jeremy
(3,724 Views)
You should VISA with serial, but if you are modifying an existing program and conversion to VISA is not possible at this time, you can go to
C:\Program Files\National Instruments\LabVIEW 6\vi.lib\platform\_serpsup.llb
to get the compatiblity vi
Ray K
(3,724 Views)
