Serial communications behaviour different when application built
Hi all,
I have a program that communicates to devices via a serial connection on a Mac machine (using a USB to RS-232 cable).
I intend to build an standalone application for the Mac out of this. However, I've noticed that serial communications that work completely fine when run on LabVIEW ceases to work once you build the application and run it. I.e. writing strings to a device works fine when run on LabVIEW but when running the standalone application it stops working (expected response from device being written to does not occur, in fact, there was no response).
Anyone have any ideas on why it behaves differently?
Thanks!
cheers
(3,613 Views)
Did you include the VISA library in the build specification for your installer?
(3,596 Views)
This might be really elementary, but I can't decipher in which part of the standalone application's build specifications I should add the VISA library.
I'm working on a Mac OS X machine with LabVIEW 8.2, if that helps.
Again, thanks.
cheers
(3,564 Views)
You need to have NI-VISA Runtime installed on target computer.  Version should match the version of NI-VISA installed on the development machine.
(3,550 Views)
