Serial communication between computer and cRIO
I am not new to Labview or cRIO programming, however, am venturing into to my first trial at serial communication.  I have a controller (not of NI origin) that sends data over an RS232 serial network that I would like to log parallel to data that I am collecting with a cRIO.  Before I get to integrating, I am attempting to test communications using a serial cable, my computer and hyperterminal and the cRIO serial port.  I have followed and validated the operation and drivers with the following:
How to Do a Serial Loopback Test
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHn8CAG&l=en-US
However, when I try to use the following example, I get nothing:
Serial Data Transfer Between cRIO and Host
https://forums.ni.com/t5/Archive-TKB/Serial-Data-Transfer-Between-cRIO-and-Host/ta-p/3521823
Any ideas on where to start?  I greatly appreciate any advice.
Thanks.
(3,766 Views)
Is your cable a straight through or a NULL Modem?  I think you will need a NULL Modem cable.  That basically means the the TX on one side is tied to the RX on the other and visa versa.
(3,764 Views)
Accepted by topic author Eric_Lang
I've confirmed it is a straight through.  I will try a null modem cable.
Thanks!
(3,759 Views)
