Serial VISA
I work at ANSTO,  have a LabVIEW 8.5 with Window XP.
I like to use “Instrument I/O assistant” through serial port to control (communicate) with Vue-MVseries Laser Diode controller. As required by the Vue Controller, the command must terminated in the following two eq ways:
1) A line feed or “new line” character (ASCII 10)
2) A “great than” character ‘>’ (ASCII 62)
 In the window of “Selection Instrument” sub-window “Termination character”, I try to select <custom>, than I type whatever character, such as “>”, however, when I click run, it always end with “/n” instead of “>” as I wanted. It seems that the <custom> out og work. So that when I write a input, it always end with error: Could not perform operation because of I/O error.   VISA Status code : bfff003e”
I have tried all other possibility with different “Termination character”, <none>, “/n”, “/r” and “/t”, but none one works and shows the same error”
Could you please tell me how to resolve this problem, for making communicate between the Instrument to labVIEW 8.5.
 Thank you. Best regards.
Bin
(3,827 Views)
Use the example basic serial read and write to find out what works
greetings from the Netherlands
(3,809 Views)
