Serial-Data LVDT
I have a LVDT connected to my COM1 serial port. This gives me around 7000 readings when I read the COM Port. It outputs a string like "N  +0.642...."  to signify the flatness of a section. The problem is that I am getting a string (Read Data) like shown in the VI and am not able to convert it into an array of readings in DBL format, which is required for further processing.
I have attached the VI that I am using.
James
(1,705 Views)
1. I would change your termination character to be a Carriage Return (13).  Then each read will be a single measurement.
2. Use Match Pattern to find "N " (notice I have a space in there).  Then the "after substring" will be your number.  Use Fract/Exp String To Number to convert it into a DBL.
(1,693 Views)
