Sending string through SerialVISA Write
Hi all,
I am trying to create a communication through serial between LabView and Arduino but I am having some problems.. Your help would be really appreciated.
I have attached the .VI to make my problem clearer.
I want to send a string to Arduino basing on what the user decides in the front panel through some radio buttons.
I've got a string indicator to know which is the string I am sending..
The problem I am facing is that actually it seems that I am not sending values at all and I am not getting why..
Do you have an idea of what is happening here?
Thank you so much in advance!!
(3,067 Views)
Hi
You forgot to select the visa resource and you need to specify or use defaults of the visa serial open.
I added the VISA session at COM3 but maybe you have another port to the Arduino.
Check if you need a LF after your message otherwise disable the Enable Endchar.
I would also use another way to select and build the string e.g. in a subvi to leave more space for the display of results.
greetings from the Netherlands
(3,043 Views)
First of all, thank you so much for your help!
I was using COM3 and I tried again fixing that issue but nothing happened..
I add a Serial Read with an indicator and I am actually not sending anything ( nothing is shown in the serial buffer) but I am not getting errors..
I attached the modified VI, in case you have the chance to take a look at it.. I would really appreciate it.
I used a couple of times the Serial Write function it never happened to me..
Thank you so much again!
(3,020 Views)
I found the following error:
Error -1073807360 occurred at Property Node (arg 😎 in VISA Configure Serial Port (Instr).vi->GUIv2a (1).vi
Possible reason(s):
VISA: (Hex 0xBFFF0000) Unknown system error (miscellaneous error).
Someone knows which could be problem/s?
Thanks!
(3,012 Views)
Did you connect the Arduino to a serial port or directly on the USB bus? When direct USB any baudrate is OK because the USB is just simulating serial. I can check later with my Arduino. What software runs on the Arduino? Or is the Arduino environment, still busy with the bus?
(3,001 Views)
